Has anyone ever used Nippon ENEOS oils?
PIMking
2,781
4
Jan 29, 2008
tuscaloosa, Alabama
Right now I have some Nippon ENEOS gear oil GL-5 75w-90 for my transfer case and rear end.
I have redline GL-4 MT90 for the trans.
I read the reccomendations on TRE's website for what to use in the trans. I have a stage 3 TRE. Im going to drop the trans this weekend and I have those oils ready to go but want to see what other people thought about the NIPPON ENEOS oils. I have read enough about redlines.
I use there syn. motor oil, from extreme psi. For the trans I'd use the EVO MR 6 speed factory fluid. For the t case and rear I'd use Redline heavy weight shockproof. Quoted from Jack's Transmissions: "Q: What kind of gear oil do you recommend?
A: For our DSM and 3S transmission rebuilds we recommend factory Mitsubishi 6-speed manual transmission gear oil from the 2005 Mitsubishi EVO MR. (Part number mz313376). This is the best oil to use as it has the perfect blend of friction modifiers to keep the tranny shifting smoothly and prevent gear failure. Please make sure you use the proper amount as specified in your owners manual (typically 2.4 Qts.) Gear oil choice is very important and varies based on preloads and synchro blocker ring design, therefore it is strongly recommended that you stick with this fluid for our transmissions. If you are unable to locate Mitsubishi MR 6-speed oil from the Mitsubishi dealer, Redline Heavyweight Shockproof 50/50 mixed with Valvoline 80W-90 gear oil will also work just as well. For transfer cases and rear ends, use Redline Heavyweight Shockproof ONLY. It is especially important to use only Redline Heavyweight Shockproof fluid or Mitsubishi dealer t-case fluid in EVO transfer cases. DO NOT use Synchromesh, BG Synchroshift I or II, or Royal Purple. These fluids will destroy synchros and gears and void your warranty! THESE ARE THE ONLY FLUIDS WE HAVE EXPERIENCE WITH. If you ask us "Will xyz fluid be okay?" we won't have an answer for you."
source: DSM Transmission rebuilds
Thanks, I was really hoping more people have used it before.
