has any one installed after market flywheel &clutch
hermangoodgame
Jun 16, 2011
Farwell, Michigan
Hi guys i have installed a stage 2 clutch and lightened flywheel and couldn't get the the release/ fork arm to move enough to disengage the clutch so i replaced the Master and slave cylinder still could not get it to work right so i replaced the stage 2 clutch with a stock one just in case and still having the problem. If i pry the release arm with a pry bar the clutch disengage is and i bleed the system it to death
check to make sure you didn't bend anything taking it out and putting it in. you may have bent the clutch forks or line.
Damn that sucks bro.Similar issues I had with my 1g with not disegaging.I think an extended slave rod is more like a bandaid.If it worked without it before it should be working fine.My problem was that my clutch pedal needed a rebuild.You could also try shimming the fulcrum ball that the fork goes on.Basically put 2 washers on it but again its just a bandaid.
