2G Harness issues
96WhiteTSi
127
4
Mar 6, 2009
Reno, Nevada
Hey guys... Im having huge issues with my 2g... let me start from the top
I was in process of removing heater core and air bags in my TRACK ONLY car... well I figured if I am removing the core I wouldnt need the harness connectors. I decided now would be a good time to test my skills at wire clipping. I found out i lack the skills.
The car has no power :( my fault...
I purchased both dash and engine harness and installed and all I get is headlights and breaklights..
Im trying to get the car up and going but i am having ZERO luck.
I dont ask often and i hate to be spoon fed information. However my lack of wiring knowledge requires me to ask you to bring a large spoon'
Yes i realize this is my fault and i went in over my head...
I do have a multi-meter but also am very cloudy as to how to properly work one.
If you can help me please do...
i should mention i replaced the ignition switch and the MPI relay with new.
if texting works better for you or face time or whatever send me a message and i will respond to you
Thanks guys.
Take a picture of the connectors you cut off, I should be able to help you.
