hardware to swap turbos
Venom55
142
May 3, 2003
Just wondering , ill be swapping my dead big16G for a small 16g and was wondering, when changing turbo , what gasket and hardware do i need.
Like crush washer , 7cm gasket and j-pipe gasket, is that it. And does anyone have the part number for these.
thank
It is a good idea to change out alot of the gaskets to avoid future problems but honestly I have reused the stuff on multiple swaps and never had a problem. If something was obviously messed up I'd change it but not if it looked good still.
Anyway, if you want to do it all while you are in there pick up a J-pipe gasket, exhaust manifold gasket, turbine to manifold gasket, turbine to O2 housing gasket, 2 oil return gaskets (unless you leave the oil return bolted to the pan, then get 1), and new crush washers for the oil supply. Any of the DSM vendors should be able to supply these parts just with the description.
