Hard to Shift
Andy123
93
Sep 24, 2008
Mississauga,
Tried another friends car, realized mine is a tad hard to shift into. I looked at other threads. Should i possibly try to bleed the line, and change the fluid?
btw its into every gear, and sometimes makes a grinding sound going into reverse. Like you go to shift and it just does a grinding noise.. you try again, works fine.
ill check the synchros even though it doesn't grind. Only hard to shift into 1,2 and 5th and once and a while grinds when going into R. ill try those mods though, see if they help.
