1G Half shaft seals same as axle?
The second link is what you are looking for. Half-shaft and axle are used interchangeably. On the driver's side, it would technically be an intermediate shaft seal if we are discussing an AWD DSM.
okay cool, yeah its awd 1g 5 speed, so there should be 2 on each side of the bearing on half shaft, and one one the driver side axle?
The seals you are referring to are the seals on both sides of the trans. My apologies if my intermediate haft comment came off confusing. The driver's side axle is two parts. The inner portion (intermediate shaft) goes to the trans. The seals are 46 and 67 as referenced in the diagram below: (disregard that the diagram is for a 97)
If you want to replace the intermediate bearing/seals:
http://www.jnztuning.com/product_info.php?products_id=3573&osCsid=5ebdd2a1677002666ae67754552afbdb
is it possible to just get the seals? i dont have a press to do the bearings and this one seems good, and i had a spare axle seal that i used on my passenger side and its to small for the shaft.
