b-morr
- 190
- 0
- Jul 24, 2007
Aurora,
Florida
Will I need a camber kit with H&R Sport Springs? I will be using Tokico shocks.
No. I'd say that with the ~1 inch drop the OE's will give you, you wont need a camber kit up front. It should land you a nice negative 1* or so of camber just from adding the springs. However, I still like the idea of having a kit simply for nice, complete adjustment.
A rear camber kit will still be required.
What about the Sports? Same deal?
Thanks,
Tom
No. The average drop for the H&D sports in 1.7"F and 1.4"R. You'll need an alignment kit in the front and some more washers or an alignment kit in the rear.
On average a 1" drop will give you 1 degree on negative camber. TOE is more important than camber and toe goes out of spec after a drop, so you'll need an alignment after you drop your car.
So if you get the OE's then there is enough TOE adjustment left on the stock setup to bring it back into spec but if you get the SPORTS then the drop is larger and there isn't enough TOE adjustment left on the stock setup to bring it back to spec so you have to get a camber kit, correct?.
I have no idea. I've never had H&R springs on a car. You can get away with 1 degree of negative camber in the front without an alignment kit, if your toe is in spec - is the point that I was trying to make.
I have Eibach Pros in my AWD with a 1" drop, no camber kit in the front but I have RRE's kit for the rears.
Don't worry about your toe. Of course it will be out of spec after lowering, but not only is there no kit for adjusting your toe, but the alignment shop will have no trouble getting it back to spec using your existing equipment.
Did you get the TOE aligned at a shop after the install?
Tom
Yes, my toe was brought back to factory specs after I installed the shocks/springs. On 2Gs - toe can be adjusted, camber can be (if you get an adjustable kit) but you can't adjust caster.
As for the front camber kit on the H&R OEs, it is personal choice. You don't need it. I run -ve 1 degree camber on my front tires with Eibach Pros and have ran it that way for the last 2 years.
Thanks for chiming in, asian312, someone with direct experience from owning such a setup.
I only say eccentric bushings for a couple of reasons:
a) to uphold jtoby's fine work here in the handling forum (he very much preferred the bushings)
b) the ingalls-type kits, such as adjustable balljoints and anchorbolt types, can potentially reduce suspension travel and cause the upper control arm to smack into the inner fender well.
