Resolved GST Trans Fit Spyder GS?
Solution
Yes, a GST transmission will bolt up to the 4G64 in the non-turbo Spyder. Be sure to remove the pilot bushing before attempting to mount the flywheel.
Also, be aware that the axles would need to be changed - the GST uses 27-spline axles at the differential where the N/T Spyder uses 25-spline axles.
Solution
Sounds good thank you boss
