gst radiador fan wiring harness
Cruciatus111
50
6
Oct 10, 2013
Honolulu, Hawaii
does anyone know where I can get a new harness for my radiator fans? the previous owner upgraded the fans to mishimotos but he hadn't reused the old ones and decided to make his own harness, or are there any other solutions to fixing this? I've tried hardwiring it, with splicing thepower into one of the fuses in the cabin but it blew out in a few seconds of running, or could I just cut the female connector off and just splice them together?
You can find pigtails just about anywhere online! Google BLah blah blah "whatever fan that is" pigtail or connector and you should be in business.
Did you try just wiring them together? That end looks melted or something,
If you can't find a pigtail, I'd lop em off, strip the wires, connect, test functionality, solder and rubber shrink wrap, then hang the wire where it won't be a issue.
