Wiring harness problem
KevinRR
236
Sep 11, 2007
Milwaukee, Wisconsin
I bought a 95 Talon awd a couple of months ago, but it seem to be a never ending nightmare. I had to replace the front body harness with a new one. After taking out the harness and putting in the new one. I have one connector that I can't seem to find anywhere. There are three blue connector that is located right behind the fuse box by the clutch pedal. I plug the two blue connector in but can't seem to find the third one. I have taken a look at my 97 GST which also have three blue connector. If anyone have a 95 that would be willing to take a look under there dash and see if all three connector are plug in that would be great.
Is the harness out of a 95 as well?
The blue connector is not part of the harness I replace. It was in the way so I unplug it, but I forgot if the third plug goes in to anything since I can't seem to find it.
I hope this helps..
Bigger
Thanks EuroDriver I found out the plug is used for factory security system. And here the picture(thanks to someone on dsmtalk) of the blue connector I'm talking about.
Those all plug into the fuse box.
The black connector is plug in the fuse box, but the blue one connect to it own plug. The third one I couldn't find is use for the factory security system. What made it more confusing was that I look at my 97 GST and found all three connector connected. And I forgot that the gst have a factory security system. Problem solve guys and thank for the help.
Oh, yes your correct. The black ones all connect to the fuse box. The 3 blue ones connect to 3 blue connectors coming from the car.
