gst 20g turbo set up
eclipse_rst
39
Dec 5, 2008
LaGrange, Georgia
im about to get my hands on a gst. i would like to know what would be the proper set up for a 20g turbo?:hmm:
You need to do all of your maintnence first. Timing belt,tensioners ect. Then start with upgrading fuel injectors,fuel pump, afpr. I would suggest using the search button this has been covered often.:thumb:
Always start with maintanance. Lots of boost breaks old parts easy. Use the basic upgrades first get to know the car and then move onto a bigger turbo. Lots of supprting mods for a bigger turbo if you really wanna use it.:D
Isn't a frank level 5 a td06h turbine wheel with a 60trim garrett compressor wheel not 20g?
Not that it matters much because it's jsut an even larger compressor than the op wants and the largest turbine the op probably will get with his choice.
That's correct, Matt. Not even close to what a real 20G generates in terms of airflow, but it is in a 20G compressor cover and turbine housing so I guess it still counts.
