Any suggestions for my 20g set up?
96-Talon-TSI
Apr 14, 2011
Harker Heights, Texas
I just had a fellow member build me a 14b with 20g guts and a evo III 16g hotside. What I need is some suggestions on install kits, o2 housing,and a good 3in downpipe that I can weld up to my stock exhaust. I have a electronic cutout (3in) that I will be welding on the downpipe. I finished all my basic maintenance including a new head gasket, decked head, valve job, and complete timing kit/water pump. Any suggestions would be much appreciated! Thanks.:hellyeah:
According to you profile, it seems you are still running the stock T-25
If you searched you would have found that 2gs require a bit of tweaking of the stock system to fit a MHI turbo. You can always buy an install kit also.
http://www.dsmtuners.com/forums/newbie-forum/326733-definitive-14b-16g-homemade-install-kit.html
EVO 16G install
http://www.dsmtuners.com/forums/new...tall-kit-feedback-previous-buyers-please.html
Are you still using a td05 or the td06 compressor housing?
What kind of budget at you working with to complete this set up?
As far as o2 housings, you can use a 2g and port the heck out of it, you can purchase a tubular one. The only thing I would stay away from is the evo3 o2 housing. It angled in a position where most downpipes for 2g will not fit it. 3 inch downpipes can be found to bolt on to the existing exhaust system.
Where do you plan on running the wastegate? Internal or external?
Comp housing is td05, I would like to finish the turbo and exhaust work at around $300-$400, and as far as wastegate goes I am trying to avoid boost creep and I heard a external would help along those lines. Honestly that is not a subject I am familiar with and could definitly use some pointers.
