Gs-t to gsx conversion?
We have a friend in town and he did the swap and i was able to find him a crashed donor gsx car. He took the fuel tank, driveshaft,transmission, transfer case,and so much more with rear diff and subframe in one piece, etc. There is a little bit of fab work in the tunnel and other misc. drilling, This swap was just a pain in the ass. He ended up getting it done and the car ran great. If we didnt have that crashed donor car, this swap would have been expensive. I respect anyone thats accomplished it, but if you dont got a cheap donor, you might as well buy a running gsx, seriously. Im not trying to steer you wrong because its doable, but do the math before you buy your friends car and add all the swap pieces if your lucky to find at junkyard. All together with matching transfer case and differential due to gear ratios.
