Ground Wire kit in but now idle surge is back
vtracer20
407
Oct 1, 2004
Milton, Vermont
So i replaced my ground wires as with the groud wire kit install from the article but now i have idle surge anyone can help me with this?
Make dead sure all the grounds are right and tight to metal(not paint). Check around for anything you may have disturbed/disconnecte don accident while doing your last project.
Follow the VFAQ on setting your idle. You have to ground a two items with double ended aligator clips and then adjust the BISS.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
