Grinding Noise
konigtalon
40
Jan 5, 2006
morehead, Kentucky
Hey there guy's I have a new problem LOL. Everytime I let off the accelerator or is I keep my car at a certain speed I hear this grinding rubbing noise under the rear seat. I have replaced the carrier bearings driveshaft was fine and I changed the fluid's in the rearend and transfer case today and it is still making the same sound!!!! Please help with any suggestions I also replaced the rear side differential side gear today it was bad. Nothing seems to help this problem. Thanks, Dewayne Elliott
I am currently having the same issue with my car and had this issue on my last car too. On my last car, part of my cat-back sat right up to the body of my car, and everytime I would let off the gas or even sometimes at idle, it would rattle the whole car. Currently, my GSX is doing the same thing, and it started after I had taken off my exhaust to inspect it. I have yet to check it to see if it's my exhaust rattling, because my new 3" turbo-back is coming soon. Can't be 100 percent sure this is the problem but just a suggestion. Hope this helps.
Comming from the back huh? Strange. I have that issue on mine, but it's a wierd noise from the front. I suspect the transfer case on my car. I'd check for rubbing like suggested and perhaps wheel bearings as well?
