Grind noise from transmission
hurricanes71
149
Nov 9, 2011
clarksville, Tennessee
Grinding noise when in neutral when I revv up. I also get the noise when I am driving and I let go of gas at 3k or above rpms and the car will have grinding noise and as soon as I press in clutch or throw in neutral it goes away. I am thinking its input shaft but I keep reading and I keep seeing different responces to people with same issue. My car also shakes like crazy when coming to stop from a high mph. I cant get above 60 without it shaking like wheels about to come off.
Eclipse tranny noise - YouTube
Yikes! I would very highly recommend that you stop driving the car. A very common problem is intermediate shaft tapered roller end bearing failure in the GS-T trans and it sounds like you have it. Now that these cars are getting old, we see a lot of them which have been continued to be driven until the bearing falls completely apart and all of the rollers from the bearing destroy the gear-set in the trans and it is almost completely ruined. It may have already happened from the noise I hear.
I have a lot of used GS-T gear-sets if you find yours are destroyed (to save on money). I also have a new gear-set for the GS-T trans which has twice the strength over the strongest HD gear-set anyone else uses, if you want to go that route. I haven't put them on the sit yet, but they are awesome!
The vibration at speed could be several things:
1) Warped rotors (very common)
2) Out of balance tire
3) dead shocks
That's all I can think of for now. Good luck!
Jack
yea it does go away when I press clutch in. But with it going bad what all could be damaged?
...with it going bad what all could be damaged?
...A very common problem is intermediate shaft tapered roller end bearing failure in the GS-T trans and it sounds like you have it. Now that these cars are getting old, we see a lot of them which have been continued to be driven until the bearing falls completely apart and all of the rollers from the bearing destroy the gear-set in the trans and it is almost completely ruined. It may have already happened from the noise I hear.
In case you missed it. ;)
