good place to get rockers and lifters?
Wild93GS
67
May 25, 2011
Racine, Wisconsin
I recently blew up the head on my 93 gs and am in the process of converting it to a gst and I need to replace the rockers and lifters. I picked up a set from mitsu graveyard for only $20 but they're all scored to hell and wobble from side to side enough that I can see the bearings in them. I need a good reputable place to get rockers and lifters from so I can continue my build. Any suggestions would be helpful. Thanks in advance.
Thanks. I didn't even know extremepsi.com had them. I've been on that site so much and missed it.
His car has a 4g63 but that site should have them as well. I highly recommend Parts Dinosaur.
Those 420a rockers aren't going to work on the 4g63. I find it hard to believe that your old set has anything wrong with them, i literally have probably 100 of these that are used, and not one single one is damaged, i would feel fine to use them in any engine. You will be able to see the roller bearings if you push the roller aside on a new one or a used one.
These were all scored to hell and just looked beat up. I decided to pick up a head with everything on it including some 3G lifters for $200 instead of going all new. Thanks anyways though guys.
