good mbc that holds 35psi+
When running that high of boost, it is probably best to get an EBC. With that much psi the mbc spring will get slammed open - hence your spike.
I have a hallman evo in-cabin MBC and when i run 20psi or anything over 20psi - i get spikes to 22-26psi.
To get a quality MBC you're already spending at least half the cost of a good EBC like the tru-boost or profec.
I've used an ebay nxs with a stiffer spring on my hx40 car set at 38psi. The only ebc I would trust at that high of a boost setting would be using the boost control settings of a aem or other stand alone. Most ebc's use a 3 bar sensor, so boost control over 30psi is impossible.
MBC's can work at high psi if the wastegate spring is stiff enough. It won't work so good if you have an internal WG with a large 34mm flapper.
I think the spring I have in there is just maxed out. I will go to the hardware store and go through the bin of springs, and find one a little bit stiffer and cut to size. I already need a new boost gauge. I never thought I would be going over 20psi when I bought the car haha, now the autometer gauge pegs in what i like to call "Oshit" zone where the gauge face has no markings.
