bolt that holds downpipe to frame
natertater
320
Jun 26, 2008
san diego, California
hello all!
I am trying to figure out what size bolt it is that holds the downpipe to the frame right under the oil filter. my car doesnt have one, and i just seen this while trying to put turbo back in. anyone know what specs are? greatly appreciated!!:D
Does the '94 have a bolt that holds the DP to the frame and not the block like a 1Ga?
If you are looking for the bolt that holds the DP to the block then it may be something like a 10mm X 1.25 or 1.5 and should have a 12mm six sided head. I am not positive on those bolt dimensions. You could always find one at a yard for the special price of five finger discount.
i will try it out. i think i have a M10-1.25 sitting around, but it looks a little bit bigger than the m10 that i have. maybe its an m12? i will try it out, thanks for the reply!!
It may be a 12mm with the 14mm head. Any bolt that has the correct thread pitch and is not too terribly long will suffice. It may take a little experimenting to find the right bolt.
