2G Going ewg
waulpalker117
40
Apr 14, 2015
Inverness, Florida
Thinking of going ewg since my iwg is not functioning properly on my 20g anyone have any good brands to go for the exhaust manifold or brands to stay away from. Most likely going with a tial wastegate just not sure on the rest.
Thanks
There are so many companies out there that make quality manifolds. The choices are almost endless. But, in your case any of the named companies will work. If I were you, I would research and figure out why the internal gate is not working on your turbo. instead spending money on a manifold and wastegate, save your money and figure out what's wrong with the gate.
Seems to be on the exhaust side of the turbo the small sleeve that goes in between turbo and wastegate rod is binding and causing wastegate to not close and stay open
  • Wanted 6 bolt NT water pipe
    • chrisman287
