GM 3-bar MAP sensor reading
FarNorthDSMer
Mar 27, 2012
Wasilla, Alaska
Hey guys, I just decided to begin the switch over to Speed Density, got everything wired in and what not, but I'm running into a problem. The sensor came with the car when I bought it from the previous owner, so I have no idea how many sets of stairs it fell down, bottom of boxes it saw, etc. At idle, it doesn't read anything below -0.8 inHg, which is basically logging my idle half way down my SD table, while my gauge reads 20-21 -inHg. All the logs I've pulled up have been people running the Omni 4bar, and showing a normal amount of negative pressure. Faulty sensor? Common problem with the GM's? As boost picks up, the MAP sensor follows right along once I'm out of the vacuum range. Any ideas would be well appreciated!
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
