Gasket for ported 2g manifold??
Infamous33
100
5
May 30, 2011
Chicopee, Massachusetts
Maybe I haven't looked hard enough or my math skills aren't what they used to be but I have a ported 2g exhaust mani that I purchased and the outlet is ported bigger than stock.
I know everyone says the 7 cm gasket, but measuring it, I only get about 58ish mm. Is the 7 cm the only choice over stock size? I plan on porting the turbo inlet to match, but that is sort of tough without a gasket to go by.. and I want to make sure of what gasket I will use before I start cutting.
Not sure where to get one, so if anyone could also point me in the right direction with that as well, thanks !!
FFWD shows an inlet gasket, but doesn't list the port size....
Well I just noticed that ffwd lists their gasket as 61mm hole, but I noticed no one mentioned the copper gasket option yet.
SEC lists what I believe to be the same copper gasket (as it seems they make most of the gaskets for ffwd..) however it doesn't list what the hole size is. I was going to call them in the morning to find out..
Is copper not the best choice, or waaay down on the list?
P.S. it is $17 at ffwd and like $12 at sec
Check this out! ;)
They go over copper gaskets a bit.
http://www.dsmtuners.com/forums/newbie-forum/342142-copper-4-layer-exhaust-manifold-gasket.html
http://www.dsmtuners.com/forums/newbie-forum/405085-exhaust-manifold-gasket-question.html
http://www.dsmtuners.com/forums/bolt-tech/398417-anyone-using-copper-turbo-inlet-gasket.html
Although Ive heard mixed thoughts on the use of Copper gaskets, I still would go with the OEM 7cm gasket! I Can't seem to find where I purchased mine, but dont be fooled by the ones selling the Thick Stainless steel gaskets as they are know to crack and fall apart! As 99gst_racer has showed in his thread.
Edit:
Here I found it at Machv.com, Not were I got mine but this is what it looks like! Also, I know you can find it way cheaper than what they have it listed for!
http://www.machv.com/oem7cmtuinga.html
OK found some VERY similar on ebay:
http://www.ebay.com/itm/14B-16G-DSM...Parts_Accessories&vxp=mtr&hash=item3cbdf809dc
http://www.ebay.com/itm/Turbo-Gaske...Parts_Accessories&vxp=mtr&hash=item589057f23e
Also I would stay away from These as they are usually found next to nothing (most of the time), but i've had a few and they ALWAYS burn up and blow through!
http://www.ebay.com/itm/DSM-16G-TUR...arts_Vehicles_CarParts_SM&hash=item4ceb7e5fb6
Hope all this craziness i've posted helps! ;)
