gas overflow at fill up
PlanZero
1,516
267
Aug 13, 2013
Easton, Pennsylvania
This only started happening recently. When I fill up, and push the little lever down on the gas pump, the pump doesn't stop until gas starts overflowing out of the fill neck. At first I thought it was the gas station's pump (which never happened before), but this now happened at three different stations. I also noticed that even though I'm on E, I never get past 10 gallons to fill her up. Wtf is going on?
From reading the forums dropping the tank seems to be the only way. You might be able to disconnect the vent line from the tank and blow it out with compressed air, but not having a 2G can't say for sure that even that is possible without removing the tank.
