transmission leaks at fill plug
96eclipsegsx56
147
Mar 11, 2011
lowellville, Ohio
I keep hearing a clanking noise whenever my car is given gas...I checked my transmission and its leaking at the fill plug closest to the front of car...i was told its a shepard stage 2...could me losing the trans oil comin out cause the noise I'm hearing or is it somethin else? Maybe my diff? And how can I fix this leak??
If it's leaking from the fill plug than you are missing the crush washer. As for the clunking noise, it is likely motor mounts.
Ok thanks...I hope it wouldn't be motor mounts...i have prothane urathane motor mounts...its not a loud clunk...its like if u loosen a cable and snap it back together...like a clinking noise...I can get a crush washer at like autozone right? What size do I need?
