gas milage
JuGs
674
Jul 20, 2008
Marshall, Wisconsin
Ok Im assuming my eclipse has a 12 gallon tank. Im getting roughly 100 to 150 miles per tank. O2 is new so i kniow its not that. I did remove the fpr sonenoid but still have the stock fpr. Would that be causing my bad mpg's? On my 1g before i tore it apart to do the 6 bolt swap i was getting 22 mpg with 650cc and 20 lbs of boost. Im only running 9 lbs and stock injectors so i should be getting twice what im getting, which is roughly 10 to 13 mpg.
Now if that is my case if I were to put my 650's back in and the afpr would that fix my issue with my mpg? Do I need the fpr solenoid to be there? I though it was fine to remove it.
Just because the o2 is new I wouldn't count it out, defective items are out there. I guess your FPR could be over-ran, but without some way of knowing your o2 trims its really hard to pin it on one thing. Best you're probably gonna get will still just be a shot in the dark. Check for fouled spark plugs, see if your exhaust smells like straight gas, you're obviously running extremely rich, and there is definitely something wrong.
The o2 is curculating properly from what i can tell so i dout it is that. before i replaced the o2 i was only getting like 65 miles on a full tank. so its improved but not to where it should be. i have a boost leak at the tb i cant seem to get rid of. though its been to cold to properly fix it. i also have 2 exhaust studs missing. but i dont think a boost leak and a exhaust leak can cause that bad of milage
I had a pesky boost leak at my throttle body that I couldnt get rid of as well, RTV works great. Definitely check for fouled plugs, or that the plug wire is even seated securely. Ive had that happen and have horrible fuel milage.
EDIT: Try filling your tank up, reset you trip odometer and run it until the light comes on. Then you'll know how far on a tank you can go.
Do you have any sort of logger or even a w/b o2 sensor? those two items right there might help solve your problem in a hurry. also is there any chance you could have accidentally damaged the o2 sensor while installing it. You know like accidentally fraying a cord or something?
EDIT: crash our low fuel lights usually light at around 5 gallons remaining. it's why so many people on this forum believed the tanks to be only 12 gallons
I have link. i do have a wb but its not installed. i thought the low fuel light came on with 2.5 gallons left
Repalce the Coolant temp sensor. When that goes south so does gas mileage
My all bone stock gsx gets 21mpg mostly city plus acationaly stomping on it.
My untuned 16g gsx i gets 18mpg average.
I think once we all put bovs on are cars we stomp on it more often to hear it :p
thats what probably lowers our mpg LOL
our gas mileage sucks. no where near other 4 bangers.
Soloution:
Sell your expensive ass turbo dsm, and buy a 420a car instead. its way cheaper than the turbo to n/t swap, and you will have extra kaching$$$ left over from the sale!!! :tease:
In other news:
New rule added to the 4g63 posting rules:
Own a 420A? READ THIS before you post in the 4G63 Forums, and be WARNED!
We've had some trouble in the past with owners of factory non-turbocharged DSMs coming into these forums and advising Turbo DSM owners to sell their cars and buy a non-turbocharged car. That is not to happen anymore.
(just ignore this one post in general)
unsure about fuel filter but i do have a new one to be installed. plugs and wires are not even a year old.
DSM's are heavy cars, esp the 2G, weighing in close to 3000LBS.
1G's were lighter - around 2600 lbs - why you got the mileage difference right there... (ask someone with a 2G and the same, or close setup you got and see how their mileage is....)
That's quite the bit of iron and steel for a 4cyl to move around..the 2G AWD chassis ... it's pretty hefty!
Tires up to pressure, or are they soft? If soft, get them tight up to recommended pressure.
I'm bone stock and being nice on the throttle around town, I just barely muster 21mpg where on the freeway, I can easily hit 28mpg with cruise on.
Stop and go, town driving with the "heavy foot" syndrome is murder.' Also, you're in "cold country" WIN, and mileage on any car really suffers during the winter since you're using 'winter gas'.
Wait until when the weather warms up and then report back to us on the mileage condition.
I have owned several 2g eclipses. my last 2g wasmodded and i got alot better milage. all my 2g got rouhly 21 mpg. my tire pressure is good
You might have to put back in the 650's if you're modded since the stock 450's aren't balanced with your system and the ECU is pushing more fuel from the signals coming from the o2 sensor calling for more fuel to get things back into a closed loop situation.
Even though the temp sensor been replaced, how's the t-stat ... working okey or stuck open? Stuck open t-stats will raise havoc with the temp sensor since the sensor will also tell the ECU to shove in more fuel to get the block up to operating temps...and into the closed loop.
