D_Eclipse9916
- 1,430
- 16
- Mar 4, 2004
Vienna,
Virginia
Alright so ive been battling this problem all the time for some reason. I have a 255 walbro in my tank. After filling up I would drive and then stop, turn the car off and come back, and all the sudden ive lost literally an 1/8 of a tank of gas, it kept doing this so one day I looked under the vehicle and it is losing gas from the top of the tank....I think. So I make sure to lossen up the plastic fitting and tighten it down again. That "seems to fix" the problem. Now 2 months later, I change out my fuel filter, and im having the same problem, and no its not from the fuel fitler, ITS AGAIN leaking from the tank. I check the fitting and its tight, and seeming to seal, anybody got any suggestions? I am about to freaking throw some rtv sealant on all the threads and do that.
Could pressure be building up, it really only happens over half tank of gas. I have my charcoal canister and all emissions equipment removed. The hard line from the tank that goes to the charcoal canister is just dumping to atmosphere. Could that be it? How bout the gas cap? Could it not be working and be building too much pressure and pushing the fuel out the top?
