Gas gauge working?
Throwback23
222
7
Apr 28, 2012
Boring, Oregon
I recently noticed my gas gauge stopped working after I pulled the pump so I pulled it back out and made sure the steps were done correctly. I moved the arm and it worked (relayed to the gauge) out of the tank but was barried beyond E, I put 4 gallons of gas in it and its still under E. Not sure why it would work out of the tank but not work in it, any ideas? Thanks
If you flipped the float over it is reading backwards. try flipping the float and see if that fixes it.
I wasn't aware you could flip the float, it seems set correctly right in front of the fuel filter sock so ill have to get to working on this and get it figured out. Thanks for the input any other input would also be appreciated!
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
