Gas Gauge isnt working?????
Robertm1212GST
146
Feb 24, 2008
Spartanburg, South Carolina
Alright guys i just installed a 255 in my gsx and the gas gauge doesnt work anymore. Ive taking it apart to see if anything is wrong and nothing seems out of place. It worked fine before i put the 255 in and now it doesnt. The gas light comes on but the gauge never moves any ideas?
This happened to me as well as some other installs... Make sure the sending unit is installed properly, the gasket and plastic lid is intact, and screwed on correctly. If not, you will have to test the entire sending unit circuit. Either the gauge itself, the wires/connectors to them, or the sending unit itself. Double and triple check your work. Its usually something simple.
Perhaps you didn't correctly put the FUEL TANK PRESSURE CONTROL VALVE back on?
-Temporarily tighten the flare nut by hand, and then tighten it to the specified torque , being careful that the high pressure fuel hose does not become twisted.
Torque Specification: 30-40 Nm, (22-29 ft.lbs)
Caution: When tightening flare nut, be careful not to bend or twist line to prevent damage to fuel pump flow connection.
Ive takin it out 3 times what is the best way to screw the lid on? Like what tool? Ive changed out gauges and it still doesnt work.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
