Garrett Big T28 (tb2578) turbine housing options.
powellds2
221
6
Dec 3, 2007
Baker City, Oregon
So I have a Garrett tb2578 or "Big T28" as they call it. The turbine housing is all cracked up and leaking and I wanted to use the turbo on another setup. My question is, is there a turbine housing that fits the Garrett tb2578 with a t3 flange? I'm looking for a t3 inlet to V band or just a t3 inlet to basically anything that I can buy a v band adapter for. I'm trying to use this turbo with an external gate, so it doesn't matter if it has an internal flapper or not. Any help would be greatly appreciated, thanks.
Would this fit the Garrett Big T28? https://www.ebay.com/itm/153450392223?epid=933352491&hash=item23ba5b2a9f:g:8B8AAOSw6GJaOSe7
There are no direct-fit turbine housing options for the DSM TB2578. It's a bit of a bastard using the turbine spec from a GT2860R but in the smaller TB25/TB28 bearing housing. Your only option is to find a clean TB2566 housing and get it machined.
