galant vr4 injector size
psx
286
Nov 25, 2009
East wenatchee, Washington
My eclipse gst has vr4 swap:D
I know this because all the labels are in german. LOL
My question is what is the stock injector size?
The ones in the car a 450 blue tops with 13g turbo
The car runs pig rich............
I'm not for certain, but you should probably swap your factory injectors back in if there is a question. Your ecu is looking for a 450cc injector, but, with that being said the cars run pig rich from the factory. I think the target AF ratio is 9:1 on a factory ECU.
Its the galant 4g63t with the cyclone intake :)
the turbo reads td04 and its small, so I doubt its a 16g
but my injectors are blue tops.
So should i just upgrade turbo size then, to even it out?
Tdo4 could also be a 9b 13g or 15g...Tdo4h could be 18t..
Probbaly not a 9b or 13g, so my assumption would be 15g...Which would be better than a 13g, but not as great as a 16g...But Justin would have to chime in and let you know for sure..
You got any pics of that? 15g mits turbo is kinda interesting..
I just did a simple google search and found all kinds of stuff on tdo4 turbo's..
That has to be a 15g..I can't remember what the 13g compressor wheel looks like..
But I just texted a guy who has a 13g, So I'll come back and update when I get the pic..
I wonder tho if say it is a 15g...I wonder if its a tad better than a 14b, with the spool of a 14b...It would be interesting to find out..
Now I'm kinda thinking 13g..Cause I googled 13g compressor wheel..And the 9b compressor wheel looked like a 14b...
Got the pic from a guy..13g wheel does look similar to a 16g wheel..
Jdm galant vr4 came with 450cc unless it was a vr4 evolution..... Those had b16g and 510cc. Cyclone has nothing to do with it.
yea they are 450cc
so the car has the right injectors, and the turbo must be a 13g
Is there a difference between 13b and 13g turbo?
Thank you, i hope ## talking about my 1gROFL
Yes there is a difference, a 13b is a Mazda rotary engine and a 13g is a Mitsubishi turbo.
