G VR4 6 Bolt Swap into 2g
Afizzle
348
Jan 16, 2013
Dallas, Texas
Got a buddy who is having trouble running vac lines from his FPR to intake mani because he has a 2g engine bay w/ what I think is a galant vr4 6 bolt. Its a 97, but he has a 6 bolt motor in it. the reason i think its a Gvr4 is because the Cyclone Inter Cooler intake manifold and it being a 6 bolt.
Image - TinyPic - Free Image Hosting, Photo Sharing & Video Hosting
Hes throwing these codes: P0443, P1105, P1400
the reason hes throwing these codes is because there are no vac lines going to and from the correct solenoids (emissions/FPR) right?
p0446 is evap system vent control malfunction. p1105 is fuel pressure solenoid failure. p1400 manifold differential pressure (mdp) sensor circuit failure. p0446 is because the solenoid in pic 3 is not hook up (not important). p1105 is most likely because the solenoid in pic 2 should have vac lings going to the fuel pressure regulator and the solenoid could still be bad. p1105 i would check the mdp and make sure is plugged in. pic 1 did not work for me.
line on the left goes the manifold and the line on the bottom goes to the fuel pressure regulator.
