6 bolt swap into 2g
beth44
Jan 27, 2007
Wildomar, California
Hello i have a 97 gst with k&n intake and 2.5 inch turbo back. Im in the process of dropping and have the CAS black and green top, tb,oil filter housing, flywheel, thrm housing, water pipe, intake, oil cooler, ignition coil, oil pan and all the 2g parts i need. pleae double check my list and tell me if anything is missing? Also im going to be running a 1g non turbo throttle body and dont know where to find an elbow to connect it with? or could i use my 2g?
from that list it looks like your planing on using a 1g head-
the point of running a 1g NT t/b is that it does not have a elbow. you can clamp a silicone coupler right to the t/b. You can buy silicone 90/45/etc deg bends all over the place.
