fwd and awd engine harnes the same
talontsi902
70
Nov 5, 2005
masillon, Ohio
ok as it says i need to know if you can put a turbo fwd harnes in an awd do the years matter ? thanks for the help in advance oh they are also both 1g cars one is 90 other is 91
so other then that the fwd and awd harnes are the same im talking about from the ecu to the engine to the everything up front ?
couldnt i just use my 90 power transister?
My best advice is look at this article and it will guide you in getting your harness ready. http://www.dsmchips.com/1990ecu.html
It shows what needs to be done to get the harness to work in the different model year. You should also look at the other link to get an idea of what is different between the two model years when it hooks to the ecu in case there are problems when you install it. If this helps please rate my post. Thanks and good luck with your project. :thumb:
yes i already knew about that website due to i was thinking that my power transiter was bad and i had an extra 91 transiter pack so ive read all that but thanks for the update
can any one tell me why i shouldnt put a 90 fwd turbo harnes in a 91 awd ? other then the transiter unit thanks
