1G Fuse box that conects to the battery
AWDgsx905speed
83
Oct 17, 2002
Brighton, Michigan
The fuse box that has 3 fuses in it that connects to the battery broke awhile back. So now that my car is down I was wondering If there was a way to bypass it safely or if there is an aftermarket fuse box or something I could get (which I would prefer to do) that would allow me to get rid of the current one. The way I had it fixed before was to electrical tape it so the copper ends contacted each other. Needless to say this was very ghetto and I am sick of having to get out and jiggle the box from time to time. Thanks in advance for any help.
My battery burned up melting the wires and the 3-fuse box mounting on the battery so I've now done my own fuse setup. I know there are two 10-amp and one 15-amp but I'm worried that if use all 10-amp fuses one them won't run properly. Does anybody have an electrical diagram that knows what amp fuse the red, black, and white wires needs.
just go to your local napa and ask for an external generic fuse box, mount it and wire it with a 2 gauge wire or so for your main power strip. As far as the red and black wire is conserned the worst you will do with a lower amp fuse is blow it, It wont affect anything ellse in the system it either works or it doesn't but don't try to put a higher amp fuse in there, you will be fine untill it shorts and then you have your self a mess and possibly a fire.
