found oil on the hose that conects the bov to the intake
HaZ
Jul 6, 2008
denver, Colorado
I was gonna replace my air filter but when I disconnected the hose that connects the bov to the intake mani I noticed some oil around the wall of the hose so... whats up with that?
yah.. i second to that.. and you may also wna check youre intake manifold to clean it up.. oil might reach your chambers.. :nono:
ok that sucks I just got the car and already something... well maybe it was from the breather hose so how can I check so I dont go out and buy it another turbo just yet
Edit: now that you mention it sometimes at idle it does kinda sound weak Ill have my dad scan it to see if its running lean. also on top of that whenever I rev the engine too high the engine makes a weird buzzing sound kinda like if a piece of metal was loose somere and its just rattling, its odd it only happens if I rev my engine or take too long to shift (it will make the sound between shifts). Ive done it in front of people and they say its just my turbo but I dont think turbos should sound like that
sorry for the double post but I did more research on this "breather hose" that was mentioned and I tink it could be just that my car also leaks oil dont know from where but after reading is seems like it could be coming from the same hose...
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
