Fuse Box Case
j_eclipse96
175
Oct 26, 2004
Laramie, Wyoming
My current fuse box case (by the air filter) in my GSX is cracked and broken in several places, but functions fine. Would it be possible to just buy a new case and swap the relays/fuses over? Or would I need to solder in the new box as a whole? Thanks.
The rectanglar metal pins in the fusebox are clipped in. Take a small knife (I used a keychain swiss army knife) and push it to the side and the pin slides out. There shouldn't be any soldering needed. I went to the junkyard and got an extra fuse box to use and tore another one apart to see how it it all was put together. Make sure you label everything when you pull them out. There are a lot of wires to get mixed up. Let me know if you can't figure it out.
