Bender
- 498
- 3
- Aug 22, 2005
Monroe,
Michigan
For those of you that don't follow my website, I broke my driveshaft and rear end at the end of the last season. I just thought I would share what I have been doing to the Tuners community.
Since I didn't feel like spending $700 for half a driveshaft, that wouldn't even be fully balanced, I decided to look into different options. Not to mention, my stock driveshaft broke at the rear end, so I couldn't use the Driveshaft Shop unit if I wanted to. Also, adapter plates have no place anywhere near my car.
This lead me to get some work done by a well respected local company, near the outskirts of Detroit. They make some of the best shafts for the Mustang and Camaro community. Again, I feel the surpassed the competition.
First thing is.. well it is a full replacement! Comes with custom transfercase yoke, 3" (3.5" option) aluminum main driveshaft, new carrier bearing, 2.5" steel rear shaft, and a custom rear companion flange.
This means the full driveshaft is balanced, not just the front section.
Also, since it is the rear section that normally breaks.. what good is it buying an aftermarket front section? This rear section uses solid high performance Spicer 1310 Neapco U-joints, made right here in the USA.
When I weighed the this new shaft from transfercase to rear end.. I got 28.2lbs. This was on a bathroom scale.. so take it as you will. I am unsure what the stock driveshaft weighs. If someone knows.. please chime in.
Now for the best part. They are selling them for $800 dollars! That is around the same price as the competition, only you get twice as much.
This may seem more like a review now because it is all said and done, but it was a discussion on the link forums, which I updated with issues and pictures as things arose or were completed. I am just bringing everyone up to speed on what has been happening over the past few months, and look forward to a discussion.
Here are the installed pictures. There are more on my site (Automatic DSM'S)
. ALso you could always put a driveshaft loop to keep the driveshaft from coming through the floor board or anything like that.
I thought you were talking about moments around joints and axis's, so I was assuming a moment around the central axis of the driveshaft.
