GRNDSM
Moderator
- 2,421
- 196
- May 16, 2002
Chelmsford,
Massachusetts
I am revisiting different driveshaft options, because I am trying to piece together parts for my Spyder AWD conversion. My original thinking was going with a one piece, CF driveshaft, thus eliminating the need to weld-in AWD carrier bearing supports. Great idea? Perhaps
if you have $2k burning a hole in your pocket
But then I found this thread and it reminded me of something:
Last few years I have been driving and tuning my friend Bruces black 92 Talon. It is a fairly quick car (consistent low 10s/high 9s), while still being in DS Eliminator Class (still has exhaust and interior). Back in 07 or so, Bruce decided to treat himself to a DSS aluminum driveshaft. As he put it, There is nothing else to do in off-season, so I will get this nice, but not necessary mod.
I had my reservations, but hey, that is his car As you can see from the photos, it is a gorgeous piece! I cant blame anyone for wanting something this pretty on their car. The shaft worked fine, until we broke a transfer case. No big deal, this happens fairly often on fast DSMs, right? That is why we always bring a spare. But we found that the yoke was twisted (it was evident looking at the splines) and we were not able to insert it into the new transfer case. Our day of racing was over and Bruce had to buy a new yoke (~$100, as I recall).
After installing a new yoke, Bruce also invested into a driveshaft loop. But on the first pass the u-joint came apart (probably due to improper install job) causing the aluminum driveshaft to get banged up with-in the safety loop. Another racing day is over.
DSS said that the shaft was beyond repair and that the best they could do is give $100 off a new one. There was less damage to the shaft before we installed the driveshaft loop! This is when thin wall aluminum is NOT your friend They will not be damaged beyond repair every time, but you do have to expect this happening occasionally.
That is when I had enough and insisted that Bruces goes back to a stock driveshaft. He did it and the car has been fine ever since! We might have broken another transfer case, but we always have a space transfer case and an OEM driveshaft on hand!
I cant fault DSS for anything in this experience. But I do consider this product unnecessary! If you still want to get it, make sure at the very minimum invest into a spare DSS yoke! Or, if you really value your race days, you might want to consider a spare driveshaft.
As for the entire pound per pound comparison, what really matters the moment of inertia of where you actually save the mass. And that is a function of a diameter of where you see weight reduction. Since stock driveshaft is only 2 in diameter (or so), going to a 3 or even 4 aluminum driveshaft reduces the effectiveness of such weight savings. A flywheel analogy does not work! First of all, you are reducing a lot more weight (going from 20 to 10 lbs), second, you are doing this weight reduction at approximately 10-12 diameter, which is very significant!
Bottom line, anyone who reports feeling the difference, is experiencing a placebo effected brought upon by the fact that they just spent $700 on something they didnt need.
Or they had some major slop in their original driveshaft components due to wear.
Back to my original problem, I think that I will weld-in those carrier bearing supports and go with an OEM driveshaft
. I do not want to create unnecessary problems.
Or they had some major slop in their original driveshaft components due to wear.Back to my original problem, I think that I will weld-in those carrier bearing supports and go with an OEM driveshaft
