Fuel Pump for TSI
91Bomb
908
7
Jul 15, 2003
US, New Jersey
I'm running 15 lbs boost on 1g with free/cheap mods and did the FP rewire. I'm thinking about picking up a spare FP to have in case my stock one goes bad. Are stock FP's completely able to handle 15 lbs on 14b or s16g or should I be looking to upgrade?
Yes it will be fine but why not just go to a 190lhp and be safe. Also unless you are tuning the 16g with larger injectors keep boost at 13psi or less otherwise you be above 100%IDC.
Well I figure I can get a used stock FP dirt cheap and if I take a real long trip I can bring it with me.
14b at 15 lbs is fine but not s16g @ 15 lbs :confused:
The 16g has a higher CFM rating; blows more air. 15psi on the 14b does not equal 15psi on the 16g. More air means more fuel is needed which the stock injectors cannot support.
Mitsubishi OEM Turbo Specifications
Flow Rates @ 15psi:
TDO4-9B-6CM2 265 CFM
TDO5-12A-8CM2 320 CFM
TDO4-13G-5CM2 360 CFM
TEO4-13C-6CM2 360 CFM
TDO4L-13G-6CM2 360 CFM
TDO4L-15C-8.5CM2 390 CFM
TDO5H-14B-6CM2 405 CFM
TDO5H-14G-8CM2 465 CFM
TDO5H-16G-7CM2 505 CFM
TDO5H-16G-10CM2 505 CFM
TDO6-17C-8CM2 550 CFM
TDO6H-20G-14CM2 650 CFM
TDO7S-25G-17CM2 850 CFM
TFO8L-30V-18CM2 1200 CFM
Max Output:
TD05-14B (stock 1st gen) 275-300hp @ 21 psi
TD05-16G (small) 345-365hp @ 22 psi
TD06-16G (large) 365-385hp @ 22 psi
TD06-20G 430-450hp @ 22 psi
T25 (stock 2nd gen) 235-250hp @ ?? psi
T3 (super 60)/T2.5 hybrid 265-280hp @ ?? psi
T3 (super 60)/T2.8 hybrid 270-320hp @ ?? psi
