Fuel pump / Electrical issues
j30-tsi-awd
83
Jul 4, 2004
jackson, Michigan
I just got done installing all of my new stuff, and i went to turn on the car and i didnt hear the pump whine(ya know how it turns on for a few seconds then shuts off) when the key is in the "on" position but not started. so i checked the voltage on the harness. no power so then i checked the white plug on the top of the sending unit/fuel pump assembly the sending unit has power but the pump wasnt gettin anything.
so i pulled a wiring diagram at work and it said to check the 30a fuse in engine bay so I did all 30a fuses were fine. So I am looking for some advice on what could be wrong? what is causing the fuel pump to not recive any power?
I am tyring to wrap up this project tomorrow so thank you for your help.
-Scott
My vehicle does not have a burn(pump on time) while in the key on position. It turns on once i am cranking the engine. Is your pump rewired? If so there should be a second fuse in the power wire to the pump.:dsm:
Wow i feel stupid. So it donst power up at all not even for a second or two? unless i crank it? A freind who is a mechanic said it does get power for a sec or two before so thats why I was confused. alright thanks alot guys. im gonna try it 1st thing in the morning ill post back if it worked.
thanks alot again!
-Scott
I have the same problem as well. I installed every thing on my car nothing.
So I used my data logger to test my pump but nothing .I did hear the relay click .
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
