fuel pressure soleniod
The fuel pressure solinoind is loated to the left of the fill bottle on the firewall with the white cap. It can be unplugged. Maybe your regulator on the fuel rail is going bad. Do you happen to have a afpr installed? Then you can see what your pressure is.
Did you replace the solenoid or the fuel pressure regulator on the fuel rail? If the regular is not working properly the solenoid wont read properly causing a CEL.
