talon187
- 1,043
- 0
- Feb 11, 2003
torrington,
Connecticut
ok heres the story i was looing under my car in the front of it and noticed gas was leaking so i stoped driving it and i got an sbr fuel line kit. I installed everything made sure none of the fitings were leaking and im still having a leak in the same place its under the car with four small lines right next to one another im guess its the fuel feed line fuel return line and 2 break lines for the rear? if thats the case and its the fuel return line can someone tell me show me a pic of where under the hood it connects? and witch one it is on the gas tank? im also going to use a -6an line for the return line if this is my problem. Im also wondering if i can just use clams on the line or i need fittings or what because i know on the gas tank its held on with a clamp. thanks for all the help. I have one more question its alittle off topic but after i installed the fuel feed line i went to start the car and i have no headlights and my gas tank now says e when theres half a tank at least.... also when i go to turn the high beams on the blue light inside the car does not come onive checked every fuse in the car and under the hood and they are all good. thanks for all the help and input
