Fuel Injector/fuel Pump
560cc off an EVO will be good for around 21 psi. i don't think you need the 720s unless your planning on a huge turbo.
So keep the 190? Can i get the 620ccs jus to be safe down the line? That wont hurt?
The 190 will be fine for the 560's, and if you can keep your IDCs down on the 660's you should be fine with the 190 as well. If you do manage to push the 660's to above 85% you will most likely need to at least rewire your fuel pump to 14v in order to keep up.
Well im not rewiring. 255 doesnt cost much at all.. Ill go with that...
But i was asking should i upgrade to 660ccs?? THey cheap as hell too, i dont see any hardm in it.
Yes.
And buy some NGK BPR7ES plugs or you'll run into problems.
With a 255 lph fuel pump you will also need a AFPR.
But you think 660cc are overkill on a 190 walboro? Whats wrong with 660cc?
Need those spark plugs then...
