Trickplay24
- 0
- Aug 11, 2013
Aiken,
South Carolina
Wondering what the best way to add a fuel cell that can be turned on with a switch. Basically the best way to drive daily on regular tank then flip the switch to use the fuel cell supply ? I am planning on using a second supply pump on the switch with a manual cut off on the main tank and connecting the fuel cell line as close as possible to the motor with a 2 to 1 link for the fuel lines. I know there will be some regular gas in the lines which is why I'm running on a separate pump and hooking in as close to the motor as possible. also dont think its anything a quick drive won't take of. Any one else done this set up or have any ideas ? Thanks.
! Have any of you done this ? Just wondering if there's any other setups ? I like it because you can drive around on regular flip the switch and go play with your friends on a Friday night. Also thought about duel injector fuel rail running a completely independent fuel cell to alleviate the regular fuel. Anyone tried that ? I have never used a duel injector fuel rail so not sure if that is possible
