2G Front upper control arm
alexr254
313
152
Jun 18, 2021
Palm Coast, Florida
So I had to replace mine on a 99 Spyder.
It was a total PITA to get it off.
I had to eventually heat it with a torch and use a fork.
Is there a torque spec I should be following when I install the new one?
For the nut that goes into the joint?
Thank you both!
I really appreciate the link and the image.
Exactly what I needed. Whoever tightened the last control arm wayyy over tightened it. And made it really tough to get off.
I don’t want to make the same mistake.
What's the purpose of setting the angle to 85 degrees?
What about if the car is lowered?
I'm thinking install it with those bolts loose, put the weight of the car on the brake rotor (with wood), then tighten the bolts. Wouldn't that be the natural resting point?
Anyone see any issues doing it that way?
That’s how I would do it, too.
