Broken upper control arm mount
conedoctor
Mar 2, 2006
Calgary, AB, Canada
So from the posts I have read this is not the first time this has happened.
I plan on welding it all back together but was just wondering if anyone else has repaired this with suscess?
I assume the boss is sandwiched between the metal that makes up the strut tower and spot welded in?
I can plug weld from behind and put some passes on from the wheel well, I think I will end up with a better product at the end of the day and I may just put a few plug welds on the other 3 while Im at it.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
