Front turn signals not working
My fuses are fine. However there are two empty fuse sockets in my fuse box. But I doubt either of them would be causing this type of problem. Maybe I'm wrong, I don't know. There are also a couple empty fuse sockets in the fuse box on the passengers side of the engine bay, near the strut mount. Where could I find a diagram of what amperage fuses to use in which sockets, and what they apply to?
Also, could the flasher unit be the problem?
no need to replace the contacts. cleaning them wont hurt but the problem is most likely that they do not make contact at all. just stick a screwdriver in the socket (with blinkers and markers switched off) and bend the contact up a little.
I'll try it, but it seems strange that both of the front lights would go out at the same time... They aren't on the same circuit are they?
Originally posted by DSMKevan
Oh yeah, I had that problem with my 90's front right turn signal lights. Once I took out the bulbs, and blew off the contacts it worked fine. I might replace the contacts eventually.
same problem in mine. fixed it the same way.
