[RESOLVED] Turn Signals & Hazards NOT WORKING
android
Dec 3, 2013
Montpelier, Vermont
('97 GSX) My turn signals and hazards will randomly stop and start working. I checked the fuses and bulbs and they are in good condition. Brake lights work too. Sometimes they will stop working in the middle of driving and work again 15 minutes later. When they stop working there is no clicking noise, the dash arrows don't light up, and obviously the outside lights don't blink. I just recently topped off my blinker fluid so I don't think that's the problem.
Any help would be appreciated.
How about relays? I am pretty sure it has to be. If your wiring was bad then your turn signals would not work at all
If i ever solve the exact same issue in my car, ill tell you how i did, It's been 4 years, since it started and NOTHING! has resolved it yet.
FIXED! Just a loose connection back behind the radio. The one with the brown top was loose and would turn the hazards on and off as I pulled it in and out of the socket, the white connector may have been loose as well.
Thanks for your suggestions :thumb:
good stuff man. i once had an issue with the turn signals but it ended up being the relay
