Front Oil seal replacement
YoYo_4G63
187
4
Sep 5, 2008
Carolina, Puerto Rico
Well i have a small oil leak, coming from the front lower part of the timing belt and is covering the belt with oil :( i've disassemble all, except the oil pump.
The bottom sprocket can be removed to access the oil seal gasket or do i need to remove the frontcase/oilpump?
Any tip or link to read? I've just found threads of ppl with their own particular problems not a how to do, thanks
No sir, front case/oil pump does not need to be removed. Only the crank sprocket. You'll have a hard time getting the bolt out of the sprocket with anything less than a powerful impact.
Note which way the crank trigger plate goes on when you pull it off, or your trigger and crank sensor are gonna get real comfy with each other :p
