Front Cover/ Oil Pump
The Topline comes with the oil pump gears, the Mitsu does not, although you can add them as an option.
You need to do some research before you delve into this project any further.
Yes, it is recommended that you replace the gears, however, you can reuse the assembly if everything is within tolerances.
Thank you for all your help, i did some further investigation and found the info that I needed.
GloriousDSM said:
arent you supposed to replace the oil pump also when doing a rebuild??
The two gears, the gear cover and the front cover, are the components of the oil pump. If you order a front cover with gears, then you have a new oil pump.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
